Old 02-14-2023, 09:57 AM   #1
986 wet compression test practicality
Is it practical to perform a wet compression test on a 986 Boxster due to the horizontal orientation. if so, any recommendations on how to effectively squirt oil into the cylinder to properly line the cylinder wall. I don't want to start and warm the engine because there is a coolant leak in one of the cylinders.
1947verns is offline   Reply With Quote
Old 02-14-2023, 10:05 AM   #2
This in not particularly necessary for running a compression test, but if you insist you can use what is called "fogging oil" spray in each cylinder while it is at BTC:
Old 02-16-2023, 10:38 AM   #3
The oil you put in there will be distributed throughout the ring/cylinder seal when as the piston moves. If you're concerned ensure the pressure has stabilized (as the oil disperses) prior to accepting a reading.
Bush Pilot is offline   Reply With Quote
