Old 02-14-2023, 10:05 AM   #2
JFP in PA
Originally Posted by 1947verns View Post
Is it practical to perform a wet compression test on a 986 Boxster due to the horizontal orientation. if so, any recommendations on how to effectively squirt oil into the cylinder to properly line the cylinder wall. I don't want to start and warm the engine because there is a coolant leak in one of the cylinders.
This in not particularly necessary for running a compression test, but if you insist you can use what is called "fogging oil" spray in each cylinder while it is at BTC:
