Old 11-21-2006, 10:41 AM   #1
Length of the standard lug bolts?
I need to find out what the length of the standard lug bolts on my Boxster?
I'm planning to put 7mm spacers on my rear wheels and need to find out what length lug bolts I would require?
Thanks in advance,
Ray
Duster is offline   Reply With Quote
Old 11-21-2006, 11:46 AM   #2
45mm Standard
+7=52mm
This is the place I got mine (23mm for rear with E65 offset wheels)
http://www.************************************************************/productpage.aspx?pid=102089&name=H%26R+Trak%2b%c2%ae+Wheel+Spacers
Also, you will need to take off the rounded bolt shoulder from your existing wheel bolt and put on the new bolts
Good luck,
Ed
Sboxin is offline   Reply With Quote
Old 11-21-2006, 02:02 PM   #3
bmussatti
Guest
Posts: n/a
Why don't you get the Porsche 5mm spacers that come complete with the longer wheel bolts. Like this:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=00004450009&Category_Code=POTEBXWH
Old 11-22-2006, 11:21 AM   #4
Thanks for info. and here's reason why
I'm buying this wheel and tire package which includes the mounting/balance, lug bolts, valves and shipment to my home for $1812.00
The wheels are ROH Drift R which are a nice clean one piece design with no rivets (easy to clean), nice polished lip and silver center to match my Arctic Silver exterior of my Boxster.
18 x 8 (50mm offset) with 2" polished lip
18 x 10 (52mm offset) with 3" polished lip
I'm getting H&R DR spacers for the rear, hence the need for longer lug bolts (45mm + 7mm = 52). This should put rear wheels at an offset of 45mm.
The tires are Toyo PROXES T1R
225/40/YR 18
265/35/YR 18
Let me know what you think and if there any issues with the rear offsets.
Thanks, Ray
Old 11-22-2006, 12:44 PM   #5
Thanks in advance,
Ray
________________________
Forgive me, but what is the purpose of having spacers? Is it to give the car a wider wheel base? If so, why? Is it just aesthetic or does it impact performance.
2000 Arctic Silver Boxster
SPQR
Senatus Populusque BoxsterRomanus
jeffsquire is offline   Reply With Quote
Old 11-22-2006, 04:23 PM   #6
In my case the rear ROH Drift R wheels with an offset of 52mm would interfere with my rear struts. The 7mm spacer would push it out to about a 45mm offset.
To answer your question, I believe it would be both in terms of both looks and possibly handling.
Anyone else want to chime in?
- Ray
Old 11-22-2006, 04:46 PM   #7
boggtown
Guest
Posts: n/a
Ya, its for clearence. Also a little better handling, theoretically.
Old 11-22-2006, 10:13 PM   #8
And it has the nice side effect of wearing out bearings quicker.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 01-02-2012, 08:21 PM   #9
Send a message via ICQ to mattgenton
a bit late but happy newyear
hi to all at 986forum.com i thought i had sent this newyears eve but it didnt send so i have sent it again all things good for the new year to all of you
- gentas
mattgenton is offline   Reply With Quote
Old 01-02-2012, 04:39 PM   #10
Duster, do you still have ur boxster? How did you like those wheels? I'd like to see how it looks if possible.
Blue 2003 Boxster S
GT2 Front bumper
GT3 Side Skirts
19" MHT Rims
Evo Intake, De-Snorkeled
CVstarBoxster is offline   Reply With Quote
Old 01-02-2012, 05:38 PM   #11
Johnny Danger's Avatar
Disregard - old post .
