Old 08-29-2022, 01:23 PM   #1
2002 boxster s runs and stalls
My 2002 boxster s starts run 10 seconds and dies any thoughts
Mrden1 is offline   Reply With Quote
Old 08-29-2022, 04:23 PM   #2
Fuel filter?
Any codes?
Radman is offline   Reply With Quote
Old 08-29-2022, 04:45 PM   #3
My bet is on fuel pump/fuel line.
Old 08-30-2022, 05:30 AM   #4
So some background info would be helpful.
Any work done on the car before the issue started?
When did the issue start?
Did it happen out of the blue or ????
So go with the simplest things first then work your way up.
Check the fuel pump fuse, the fuel pump relay and the main DME relay.
If they are good then you need to check the fuel pressure at the fuel injector rail and the fuel delivery volume. But your going to need some special equipment for those tests.
Or have a reliable shop do it.
Old 08-30-2022, 11:40 AM   #5
Drove few hundred miles in fla heat. Then idled for 10 min after that car became harder to start.thej started bucking at low speed then died. Nxt day start dieb10 seconds later.
Old 08-30-2022, 12:10 PM   #6
Check your crank position sensor.
