Old 08-01-2022, 09:36 AM   #1
Dual row ims bearing
Can someone tell me if ln Eng has a dual row bearing for a 2003 boxster
I’m looking at a 2003 boxster and the owner has a receipt for a dual row ims that Porsche installed in his car
Jimbo409 is offline   Reply With Quote
Old 08-01-2022, 09:55 AM   #2
Unless it also has a replacement engine from an earlier car, the answer is no. The dual row bearings were phased out in 2001, 2002-2004 cars all had single row bearings. Plus Porsche dealers did not do retrofits. And as I have no tolerance for people that try to deceive buyers, I would walk away as you have no idea what else the seller is trying to hide.
Old 08-01-2022, 10:12 AM   #3
Call ln directly
DreamSign is offline   Reply With Quote
Old 08-01-2022, 11:05 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
The seller may be wrong and correct.
To disambiguate, LN does make a dual row IMS retrofit bearing for cars that came with a single row bearing.
Porsche does not install them.
https://lnengineering.com/products/the-definitive-guide-and-faq-for-porsche-ims-bearings/ims-retrofit.html
Old 08-01-2022, 12:05 PM   #5
Exactly what does the receipt show as the LN part number? Is there a sticker on the drivers door jam? If you have a serial number of a LN part, LN could tell you what was sold.
Prior '70 914, '99 986 Boxster, '01 Boxster S
Old 08-01-2022, 01:16 PM   #6
Good point, and as Mike points out, if you have the sticker number or the LN part number, that can de code if it is the single row pro bearing.
