Old 05-27-2022, 10:44 AM   #1
Originally Posted by por356c View Post
Take it easy on me with this question fellas; I’ve always had manual transmissions in my Porsches, but I am considering buying an automatic Porsche. My question is, does the PDK require that you shift with paddles or can you simply put it in drive as we do with our daily cars? Thank you.
It does both.
Old 05-27-2022, 12:55 PM   #2
husker boxster's Avatar
When looking for a PDK, be sure the maint has been performed at the proper mileage / age, meaning changing the trans fluid. For 09-10, it's every 6 yrs or 60K mi and 12 yrs or 120K mi for 2011 and newer. The latter is too long a period so look for shorter intervals. If the car has been tracked, defn look for shorter intervals.
PDKs are not bullet-proof contrary to the internet myths. They need to be treated with care when it comes to maint. If there's a problem witht the PDK, Porsche's answer is to replace the whole trans rather than fixing what might be the issue (most common issue is an inexpensive solenoid). If you're out of warranty, that replacement gets very spendy.
The 09 Box S I had with PDK was an OK trans. The 14 Cayman S with PDK I had was significantly better. That car was the 1st I've owned with an auto that I thought I could live with. I don't know for sure, but I imagine the improvements came in 2011.
1989 928 S4 5 spd - black
