-   -   rear drive axles replacements .. (http://986forum.com/forums/boxster-general-discussions/82283-rear-drive-axles-replacements.html)
jaimster 05-22-2022 06:16 AM
hello Guys,
So, I'm getting back to my 01 Boxster 986 suspension components replacement
fronts and rear shocks, lower controls arms, sway links, rear drive axles (boots replacements and regreasing ball bearings where possible) fuel filter, air oil separator
ISSUES here:
after replacing boots on BOTH ends and removing inner ball bearings, carrier or hubs sorry DO NOT KNOW proper names , repacking new grease NOW
.. rear axles inner CV joint ARE rigid , NOT turning or swiveling at ALL
is that normal ?- where did I go wrong when reassembling them ?
I can't remenber how they felt when I removed them !!
any input appreciated ..
Gilles 05-22-2022 09:43 AM
Jaimster, No, that is not normal... (sorry)
Perhaps be better to disassemble the inner CV's and reassemble them again as they should move in all directions as the outer ones.
986tate 05-22-2022 09:45 AM
I think if they’re a little hyperextended or put together weird they will bind but if you bang them around a bit they will go back to normal.
Used to happen to me sometimes
jaimster 05-22-2022 11:10 AM
thank you Guys ,
I'm going to try banging them around a bit maybe they will loosen up ! if that doesn't work I will have to take them apart again .
another question :
are the end components on both inner axles interchangeable ?
steved0x 05-22-2022 05:29 PM
Originally Posted by jaimster (Post 646694)
thank you Guys ,
another question :
When reassembling the CV joint if the center part goes in the wrong way it will bind up. There is a video somewhere on youtube that shows the right orientation and the wrong one. This might be the video, apologies if I have found the wrong one.
https://www.youtube.com/watch?v=b97EjaR_btw
jaimster 05-22-2022 06:28 PM
wholy cow ! wish I had searched for this right procedure and found this video
I did it wrong - I'm going To take them apart tomorrow and DO THEM RIGHT tomorrow
really appreciated Steved0x..
jaimster 05-24-2022 07:09 PM
So I have disassembled and assembled them back - They are much FREE turning , rotating much better -
observations : the driver side which seems to be a bit longer and also moves much MORE FREER than the driver side is that NORMAl ?
and also if I were to buy and replace (the cage and race ) has anybody done that before and have an online vendor where I could order those ?
my Thinking : I have it taken apart might NOT a bad idea to rebuild that end of the CV's
your THOUGHTS ? like BOBO from HOWARD says ..lol
found them at CARID - think I'm going to order them from there 75.00 each
Gilles 05-24-2022 08:00 PM
Jaimster, IMHO you should use OEM CV joints and axles, these are more expensive for a reason, otherwise you will be removing them and start all over again..
