Old 05-21-2022, 05:13 PM   #1
1999 base
Meir's Avatar
ABS wire repair kit
Hello guys.
Need help with finding the correct part number for the rear left ABS wire repair kit.
I can find specific Boxster part number for the fronts, but for the rear I can only find 996 fitment.
Hoping someone done this repair and have the correct part number on hand.
Thanks in advance.
Edit: 2001 Boxster S no PSM.
Old 05-23-2022, 11:50 AM   #2
If I had to guess the rear 996 and rear 986 S use the the same wiring harness.
Woody
Old 05-23-2022, 12:03 PM   #3
1999 base
Meir's Avatar
That was my assumption as well.
I ordered the 996 harness and still have the same issue.
I think I was able to find it.
Part number is 986.612.953.01
I just hope someone can confirm as these are not cheap, and usually being order from Germany.
Old 05-23-2022, 09:50 PM   #4
PElican sells these and while it is not cheap, the part number you specifed seems to be the right one:
https://www.pelicanparts.com/More_Info/98661295301.htm?pn=986-612-953-01-OEM
2001 996 C2 Manual
Old 05-24-2022, 06:28 AM   #5
What is it you are trying to fix? Is it the connector at the wheel that is broken? Someone in the past week was getting ready to send a car to the scrap yard, you could have them cut off the connectors & wire so you can splice them into your existing. I did this on all 4 of my wheels as the connectors had developed cracks in them.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 05-24-2022, 06:37 AM   #6
And at a ridiculous price; dealers sell them for $80-90.
Old 05-24-2022, 12:49 PM   #7
2001 996 C2 Manual
Old 05-24-2022, 03:38 PM   #8
And just a side bar: Porsche wiring harnesses and components traditionally were supplied by a company in the Ukraine, which is one of many reasons wiring harnesses are now both expensive and hard to come by. Porsche is even allocating some new models because of this supply issue.
Old 05-24-2022, 07:21 PM   #9
1999 base
Meir's Avatar
I took me 3 months to source all the harnesses for my 996 (did all 4 corners). These were hard to get even before the war.
Thanks everyone for the help.
