Old 05-10-2022, 10:17 PM   #1
Another cluster question
My 986 is a 2000 (actually 99 stamped on the engine cover, I swear this was the period where they just made **************** up from a wiring connection standpoint)
The instrument cluster is one where there are slide tabs on the back, one on each side, that have to be pried laterally (away from center) in order to open the cluster. These slides appear to be electrical connectors
After changing out some bulbs and putting on white gauge face overlays, the instruments don't light up when the headlights are turned on, and the turn flashers don't illuminate.
I'm not sure if the gauges work (I didn't want to wake up the fam) but the lcds and the indicator lights are all working.
Fuses are fine.
I'm wondering if it's these silly side connectors? Does anyone know specifically what connections those are? Is there any way to test if they are fully seated?
Sent from my SM-G970U1 using Tapatalk
Old 05-10-2022, 10:31 PM   #2
Nevermind. It was those tabs. I thought they were seated but when I levered on them with a flathead they seated down another 3mm. Essentially you shouldn't see any of the pin exposed when they're fully seated.
But seriously though, how ****************in sweet does that look?!?!
Old 05-11-2022, 12:49 PM   #3
Gauged look good...
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
Old 05-11-2022, 02:33 PM   #4
those are known to break. Porsche even has a replacement kit with a pn for them...but can't remember what it is right now
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
