Old 05-08-2022, 01:56 PM   #1
02 Boxster S grinds going into 2nd gear
Looking to buy an 02 S where the owner says it grinds going into 2nd gear.
Is this a well known issue? Easy repair? Inexpensive repair?
Thanks. 115k miles and in good condition.
SeaNile31 is offline   Reply With Quote
Old 05-08-2022, 02:46 PM   #2
Old 05-08-2022, 06:05 PM   #3
Define expensive & then define inexpensive.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 05-08-2022, 09:59 PM   #4
Are we talking about a manual or tip?
I think you'd need to drive it. If it's a manual with a minor "crunch" which is worse when it's cold, she probably just needs a fluid change.
If it sounds like a kid learning stuck for the first time though, or if it's a tip that is chewing through clutch disks, you're probably looking at a new tranny if not at least a complete teardown. That price will be dependent on whether you can find someone to do it who knows what they're doing, but I'd imagine it's gonna be several K (unless you find a good used one on here for less). I think husker just paid 8k for a new 6 speed, just to give you an idea.
Old 05-09-2022, 08:47 AM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
Second gear synchros are known for premature wear on the 6 Speeds. Mine improved greatly with a fluid change but still occasionally grinds when cold especially on down shifts but I can live with it. If you do change it make sure you use the real stuff from Porsche. Expensive but worth it.
Old 05-09-2022, 10:28 AM   #6
husker boxster's Avatar
Expensive?
My 987 S 6spd in my CSS would crunch when downshifting from 3-2. Renowned expert in AZ said he could fix it for $1300 in parts and $600 labor. Plus shipping from Neb to Az. No brainer.
Then he found a partial tooth loss on the pinion gear - $2600
Next he said the 3rd & 4th gear synchos were past their prime - $2000
Now at $7000, I was only $1K from a reman. Ended up going the reman route. My car has 68K mi and 2-3 DEs / yr the last 8 yrs. Can't imagine a trans w/ 115K mi will be in top shape. YMMV
1989 928 S4 5 spd - black
Old 05-11-2022, 12:51 PM   #7
Replace synchro..not sure how much but i expect a lot.
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
