Old 03-18-2022, 07:10 PM   #1
PPF / Stone Guard removal from mirror
I’m not sure if it’s film, stone guard or just clear coat, but whatever it’s peeling off my side view mirror. I’ve tried draping a hot towel over it, I’ve tried a clothes steamer and even a lightly applied heat gun to to no avail. Any idea what this is and/or what do do to remove? TIA.
Dana is offline   Reply With Quote
Old 03-20-2022, 05:35 AM   #2
That looks like the clear coat to me. Best case scenario is you sand down the clear without going through the color and respray a clear coat. Generally speaking, other parts of the car are not far behind. Might be time for a new paint job? It is possible that for some reason the mirror has had a subpar repaint and the rest of the car's paint is in good condition though.
Woody
Old 03-21-2022, 01:30 PM   #3
I had a similar issue with a silver side mirror. I bought a replacement from a forum member. I kept the old one to sand down and clear coat. I just never did it.
"YouTube Certified in Various Specialties"
Old 03-22-2022, 04:43 AM   #4
Seal1968
That's clear coat peeling off.
Only 2 options:
1. gently sand (gently = don't break through the silver) and re-clear, OR,
2. sand it down completely, and spray new base coat/clear coat
If you try to wrap with vinyl, you'll likely see the creases from the peeling clear, unless you scuff them down enough.
Seal1968 is offline   Reply With Quote
Old 03-22-2022, 08:13 PM   #5
Thanks for the input all. Paint is good on the rest of the car, including passenger side mirror. I did have the hood resprayed due to rock chips, probably will do the same with the mirror. Odd it’s just one part.
Old 03-23-2022, 06:59 AM   #6
Clear coat on these cars is not that good. Have had multiple cars with clear coat problems. It just doesn't hold up
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
