Old 03-12-2022, 09:16 PM   #1
Blueish smoke when driving AOS?
Just about got this car back on the road. Been off the road since 2013.
In a nutshell
No smoke on startup
Idles good.
No CEL
Drives very good
Doesnt seem to lack power.
Smokes under load. I mean alot of smoke. Had to pull over to put the paper bag over my head so my neighbors didn't recognize me...turn off car for a minute or 2 and restart...no smoke.
I am thinking the AOS is shot and allowing oil into the intake. Car runs too good for it to be a major issue, and does not smoke on startup...oil fill cap has alot of suction..
suburban99 is offline   Reply With Quote
Old 03-13-2022, 10:25 AM   #2
Aos...............
Old 03-15-2022, 11:55 AM   #3
Def seems like AOS could be culprit, though mine only smoked a **************** ton when it had already failed. Prior to failure it just would smoke a bit on startup.
safesaxbdd is offline   Reply With Quote
Old 03-17-2022, 11:26 AM   #4
2002 Boxster S
AOS. Mine smoked like a MOFO when it happened. Good news is it shouldn't be difficult to replace it yourself.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is offline   Reply With Quote
Old 03-21-2022, 08:51 AM   #5
Changed AOS on the weekend. Stretched the J tube to make it fit using a heat gun. Will order new J tube.
Car runs good, drove it for about 20 mins. Got on the throttle a little and had a small amount of smoke. I am considering pulling the intake to clean it. If I don't pull it how long does it usually take for the residue to get burnt off?
A side note. When installing the stock hose clamp on the bellows..if you squeeze the lower bellows clamp all the way open you can tie it with mechanics wire. Then slip the unit over the port on the engine tighten bolts and snip the wire with your sidecutter to release the clamp.
Old 03-23-2022, 08:56 AM   #6
FoFoJoe
FoFoJoe's Avatar
My AOS went out within a couple months of buying the car, what a gut punch that was seeing the dash lights go spunky while I smoked like a high school bathroom.
Careful on that small tube that connects to the top of the AOS. I cracked mine when we swapped it. Easy to buy a replacement if that happens though.
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
Old 05-18-2022, 09:15 AM   #7
Replaced AOS with a cheaper off brand version...
Car is better, but still smokes a small amount when I get on it.
Removed intake no oil in intake, but small amount of oil in J-tube. (there was oil in intake before I changed the AOS to the new one)
Apparently I am not the only one that has this problem with this particular part.
Also think the lower AOS hose (plastic) is leaking. I guess i need to order the Porsche AOS and the J-tube and the lower hose..?
Old 05-18-2022, 06:18 PM   #8
+1 Need OEM AOS. This job is enough of a PIA to try to save a few $ on aftermarket. Same for coolant tank....
Old 05-19-2022, 06:46 AM   #9
Rob175's Avatar
Define "AOS" please for some of us who don't wrench. thx
98' Boxster
Old 05-19-2022, 07:42 AM   #10
Air Oil Separator
Old 05-25-2022, 12:50 PM   #11
Porsche AOS installed including new J-tube and the lower AOS hose plastic tube piece..
A real PIA to change the lower hose/tube. It is Threaded thru the legs of the intake manifold...Airbox/ intake manifolds/throttle body etc all needed to be removed.
AOS is not to bad to change.
So far good! No smoke at all. Hopefully that's the ticket! Thanks for all the input.
Old 05-25-2022, 01:56 PM   #12
Next oil change, lower your oil level two bars below the full mark (around 1/2L), which will help even more.
