Old 03-21-2022, 08:51 AM   #5
suburban99
Changed AOS on the weekend. Stretched the J tube to make it fit using a heat gun. Will order new J tube.
Car runs good, drove it for about 20 mins. Got on the throttle a little and had a small amount of smoke. I am considering pulling the intake to clean it. If I don't pull it how long does it usually take for the residue to get burnt off?
A side note. When installing the stock hose clamp on the bellows..if you squeeze the lower bellows clamp all the way open you can tie it with mechanics wire. Then slip the unit over the port on the engine tighten bolts and snip the wire with your sidecutter to release the clamp.
suburban99 is offline   Reply With Quote
