Old 03-08-2022, 07:05 AM   #1
Vza
IMS Torque
Hi, Anyone know the correct torque value for the center nut on the IMS bearing. 08 Boxster Base, I replaced the IMS cover gasket. LN Engineering says 7.5 Bentley video says 9, Pelican says 25 ft lbs. I have the larger nut that requires a 22mm socket. Thanks V
Vza is offline   Reply With Quote
Old 03-08-2022, 08:24 AM   #2
14 ft. lbs. with the use of wicking Loctite (green)
