Old 01-23-2022, 11:36 AM   #1
Boxster S Shift cables
Need help:
I have a 2002 Boxster S 6 speed. I installed new shift cables but I am unclear how to adjust them. I purchased the green plastic tool that clips on the shifter, but it will not fit mine. Guessing it is for a 5 speed. All the videos I find online are for 5 speeds also.
Is there a part # for a different tool?
Any help here is appreciated
Steve01 is offline   Reply With Quote
Old 01-23-2022, 03:40 PM   #2
shifter
I realize now that the car has a short shifter in it. So I took out the old cables without marking them thinking I would use the tool. Any ideas on how to adjust the cables from scratch on a short shifter?
Old 01-23-2022, 05:02 PM   #3
Not sure it'll help you but I've done two short shifter kits on two different P-cars with 6 speed transmissions. I didn't have the alignment tool yet found no need to adjust cables.
Old 01-23-2022, 05:17 PM   #4
Put the transmission in neutral.
Put the shift handle in the neutral position.
Connect the cables with as little slack as possible..
That is what I did when I installed my short shifter.
Never had any issues with it setup that way.
Old 01-24-2022, 08:48 PM   #5
New Numeric cables (5 speed) for sale
Not mine.. but I read a lot of compliments for the numeric cables.
https://rennlist.com/forums/market/1286692
Old 01-25-2022, 06:14 AM   #6
porschefan76's Avatar
Hi, not sure if you're still searching this down. I purchased Porsche Factory Tool 9468 from ebay and that was what I used when I adjusted my cables. That said, as stated by others, I don't recall much adjustment being needed, if any. Hope that helps.
porschefan76 is offline   Reply With Quote
Old 01-29-2022, 10:55 AM   #7
Worked great!
Thanks everyone.
