LN Spin-On Oil Filter Adapter
Checking to see what the current consensus/situation is:
I have one, it's supposedly a better design that filters 100% of the oil and let's you use easy to spin on filters.
Only con is that it makes it harder to cut open the filter and check for metal debris. |
I have an LN spin on adaptor, but it's a different one since it's part of the LN IMS Solution and includes the oil line to the IMS journal bearing. Still no problems in almost 20,000 miles with it and many oil changes.
A quick Amazon search turns up several 'can opener' style cutters for metal oil canister filters. I did not see an offering from Pelican Parts.
https://www.amazon.com/JEGS-80532-Filter-Cutting-Tool/dp/B007VR8C0U/ref=sr_1_6?keywords=Oil+Filter+Cutter&qid=16428867 21&sr=8-6 |
My 986s have the stock oil filter housings. I replace them with a new one when I get a car and every couple years after. The housings are cheap and come with a new filter. I do have one spin on adapter that came with a car and I pulled it off because it was leaking. I intend to reinstall it correctly later.
I had one on my CSS for many yrs. 2 yrs ago the gasket between the adaptor and the engine got old / brittle and was leaking oil. L&N sells a replacement gasket. But this was after 5-6 yrs of usage. Not a big deal.
You should defn consider a spin-on if you're going to do any track days. Any "agricultural driving" could result in a cracked / broken OEM canister. |
https://www.youtube.com/watch?v=wyta_Cjhej4 |
It never ceases to amaze me that people will spend $1K for a new cell phone, or car audio upgrade, but balk at spending $50 for a tool they will own forever, and one that could catch a developing problem that could end up costing them dozens of times that amount.
Yeah but John, did you watch the video? (Just start at 2:00 if you want to skip all the extraneous lead-up BS)
The tin snips work just fine! And I already have tin snips...why spend money on something that I clearly don't need? :confused: (And by the way, I've got the same cell phone I've had for many, many years, and the audio system that was in the Boxster I bought in 2006 remains, unchanged. :) ) |
I watched the video, and what is saw was metal butchery that took way more time than is required (the author sped up that sequence to hide that fact), and left the filter housing with a lot of edges to cut yourself on. The proper tool will open any filter as fast as a can opener opens a can of soup, with no jagged metal.
Acknowledging right up front we're hovering dangerously close to flogging-a-dead-horse territory, try this one on for size, starting at right around 0:38.
https://www.youtube.com/watch?v=zrH92W6ODy4 Mission completed in slightly over 30 seconds, no video speed-up required. Sure there's sharp edges involved, but we're all big boys (& girls) here—I think we can avoid serious injury. (The first guy did recommend leather gloves, admittedly probably not a bad idea. But we've all got them too!) The snips seem to work, reasonably quickly, and bottom line (for many of us I suspect): there's quite a few other tools that I'd rather add to my arsenal (some recommended by you JFP!), each of which—to me—represents a better investment than a $50 can opener. If I needed to open an oil filter more than once or twice a year I might very well re-think this. |
Let's just say we agree to disagree.................
Works for me! :cheers:
Before anyone goes running down that pathway I should probably point out a couple things. One, a confession: I’ve never used the tin snip technique on an oil filter, so take my ‘recommendation’ (if that’s what it was) with a grain of salt. It looks pretty easy on the vids, and I have no reason to believe that’s due to any kind of video manipulation of reality (other than the speed-up effect that JFP referred to). Seeing them (the vids) has just encouraged me to give it a try next time I change my oil. If it’s a PITA to do or is otherwise not a useful technique, who knows? Maybe I’ll buy the fancy can opener. Two, if I were 30 years younger I probably would do that right off the bat anyway. At this point in my life I've got many fewer oil changes left ahead of me. I just feel like I want to try the tin snips and continue go that route if it works as well as advertised on youtube. Sicklerville eh? Another south Jersey boy. I’m originally from just down the road…Woodstown. |
Installed on the 986 and the 996. No Issues.
| All times are GMT -8. The time now is 09:12 AM. |
