-   -   Opinions welcome before I dive in (http://986forum.com/forums/boxster-general-discussions/81927-opinions-welcome-before-i-dive.html)
MYRX 12-28-2021 02:30 AM
Took the 2000 S out for quick spin yesterday. When I returned home, I thought I could smell a faint odor of oil, (hot oil) coming from the engine. Car has never leaked oil. IMS bearing and rear seal have been replaced. Any ideas before I do an engine inspection
Starter986 12-28-2021 04:20 AM
The first place I'd look would be the spark plugs area. You may have a leaking tube(s). Remove the rear fender liners (easy/gravy) and inspect the plugs/tubes.
:cheers:
CrisZenithBlue 12-28-2021 05:42 AM
I second the spark plug tube theory, the most common place these cars leak from. Most of the times it's the O rings, cheap fix!
MYRX 12-28-2021 08:44 AM
Sound advice, will do. Changed the plugs when I bought her three years ago, and I did not replace tubes and o rings and I probably should have.
