Old 10-26-2020, 04:50 PM   #1
Vza
Fornt Suspension
Hi All, Replaced front shocks,strut mounts,strut bearings,wheel bearings, control arms(wishbone). Now...I'm getting a creaking sound when I turn the wheel. I finished on Saturday and drove the car all weekend and just noticed it this morning.(Mon) Any thoughts? V 99 Boxster Base
Vza is offline   Reply With Quote
Old 10-26-2020, 08:33 PM   #2
It sounds like a bad spring top bearing, perhaps was defective..?
Gilles is offline   Reply With Quote
Old 10-26-2020, 08:56 PM   #3
Vza
That would be a drag. You're saying that cause the strut rotates when the wheel is turned causing the creak noise?
Old 10-26-2020, 10:11 PM   #4
A8ked's Avatar
It may not be related to the work you did, have you checked the power steering fluid level?
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 10-27-2020, 08:42 AM   #5
Vza
No I havn't but its not that type of groan, its more a of a squeak/ creak from rubber. Sounds like bad bushings on a control arm.....but they were replaced and it does sound like its coming from the top of the shock tower. I havn't opened the hood yet to give a listen. V
Old 10-27-2020, 08:52 AM   #6
1998 Boxster Silver/Red
Maybe spray a litle lubricant on the suspect bushings. If the noise remains... hmmmmm. Good luck.
1998 Porsche Boxster
Old 10-27-2020, 10:11 AM   #7
Vza
I read to back off on the center nut 1/4 turn. Going to try that at some pojnt.
Old 10-27-2020, 10:12 AM   #8
Yes, the noise would be something like an unwinding, snapping spring..
Several years ago, after installing a set of coilovers on the 987CS, I got a creaking noise when turning the steering wheel, and after removing the strut again I noticed that I didn't removed the bearing from the OEM strut and didn't install it on top of the coilover spring, and this was causing the creaking noise. Please note that the noise was created by only moving the steering wheel (without the car moving).
Something happens every time I rush to complete a job or get help from my younger son (he is always on a hurry..)
Hopefully yo will find the culprit.
Old 10-27-2020, 01:06 PM   #9
Vza
Yeah....It happens parked and while driving I can hear at a low speed. I'm gona back off on the nut see if that does anything. Otherwise pull it out and replace the bearing. V
Old 10-28-2020, 09:11 PM   #10
Vza
Sort of went away today. Don't know what to think. V
Old 10-22-2021, 11:22 AM   #11
Anyone try PBBlaster for this type of squeak?
deemce1 is offline   Reply With Quote
Old 10-28-2021, 11:08 AM   #12
worked like a charm
Absolutely no squeaks after PBBlaster injection. Great tip as the squeaks were driving me nuts.
