Old 10-18-2021, 02:50 PM   #1
El Vikingo Tropical's Avatar
Piston clip & camshaft tool
What type of tool do you use or recommend for a amateur like mi, I just need one good enough to assemble two or three engines.
Is the “made in chine” ok for this?
https://www.ebay.co.uk/itm/174865022935
El Vikingo Tropical is offline   Reply With Quote
Old 10-19-2021, 02:09 PM   #2
I used one similar to this, worked perfectly.
Old 10-19-2021, 07:33 PM   #3
Thanks for answering, I wasn’t sure if it’s works properly as I never used one!
Old 10-21-2021, 04:44 AM   #4
Camshaft tool
I have 1 works OK...check the plastic bar for fitting the piston clips as there are 2 different sizes of piston pin...I had to have mine machined...all that,s missing from this kit is the piece of screwed rod to compress the vario cam tensioner... but you can make 1 yourself.
EMWynne is offline   Reply With Quote
