Old 10-12-2021, 02:47 PM   #1
Door storage cover _hinge?
My drivers side door storage cover lost it springiness.i guess the spring popped? Can it be replaced ? 986.
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
Old 10-12-2021, 02:58 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
Typically the plastic breaks where the spring is mounted. I have repaired a couple with a hard epoxy such as JB Weld. Replacing the storage door cover itself is fairly simple by just removing screws. Note that if you buy a replacement cover that the 1999 and earlier are generally a plain plastic finish and the later models had the black soft-touch (easy scratch) finish.
Old 10-16-2021, 10:36 AM   #3
Cunningr's Avatar
I bought replacements for mine, very easy to install but you have to take the door panel off. Old plastic was too brittle to expoxy.
