Old 10-08-2021, 10:33 AM   #7
Many modern double-din are only that size due to the screen. Many are single DIN behind the screen. But, as Stl-986 point out, the issue is that likely nobody makes a double-DIN console made to fit on the lower portion.
To the OP, I had the same thought, and have run into the same challenges. If money weren't an object, I'd explore the Porsche Classics single-DIN carplay unit and see if it would be compatible with the 986 vs the double-DIN unit they sell. There are single-DIN units with floating screens that might work.
Radman is offline   Reply With Quote
