Old 09-14-2021, 11:28 AM   #1
Can i?
I had a atroke 4 yrs ago and cannot use my left hand or arm.i have smelled rubber burning after a drive lately. Recent water pump replacement.I am a competent car tech and would likd to pull the wngine cover and look before going to a shop.I already have an extra belt if needed but honestly can I do most of this with one hand? Maybe not the belt but at least the diagnosis. I manage detailing and such pretty well.
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
Old 09-14-2021, 12:05 PM   #2
Depends upon how capable you are with that one hand. You might be able to do it, but if you had a helper, you could definitely pull it off.
Old 09-14-2021, 12:19 PM   #3
Pulling the engine cover off wont be too hard, but i think that lining it back up to get those first few bolts in might be a challenge. If its just a timing belt you could probably do it one handed, just torque the tensioner down and hold it with your leg while removing/replacing the belt. A helper would be ideal though.
That sucks about the stroke. Life is a cruel mistress. At lest youre still able to drive though.
Old 09-14-2021, 01:05 PM   #4
Timing belt can give a smell ? I was thinking serpentine belt.
Old 09-14-2021, 01:06 PM   #5
I enjoy the driving a lot thankful for Tiptronic
Old 09-14-2021, 01:14 PM   #6
Alan, where are you located..?
Perhaps another member of this forum that lives close to you, may be able to stop by and give you a hand..?
Old 09-14-2021, 01:24 PM   #7
WALDMEISTER
BRAN's Avatar
great idea, Gilles
Old 09-14-2021, 02:03 PM   #8
Sorry, brain fart, serpentine belt. Duh.
Old 09-15-2021, 05:17 AM   #9
Im in woodstock ga just outside milton and roswell. Help welcomed.
Old 09-18-2021, 11:39 AM   #10
Someone willing to help ..?
Does anyone on the forum that lives near Marietta, GA (15 miles north) or the Atlanta area that could help a member to replace the serpentine belt? Woodstock it's about 30
miles north of the Atlanta..
Old 09-19-2021, 08:28 AM   #11
1998 Boxster Silver/Red
I can't get the new belt on for the life of me.
Removed old belt 4++ years old... shiny on the flat side. Went to install the new belt and it is missing the final pulley... next to the tensioner pulley. Tried for an hour.
Then decided to 'stretch' the belt by hanging from it a full 5 gallin bucket o' water... overnight... didn't move at all. Tried again yesterday morning. Zero.
I'll visit a mechanic this week and pay to have it installed unless anyone knows of a trick/tip.
Giles, I wish you sucess in your endeavor.
1998 Porsche Boxster
Old 09-19-2021, 01:20 PM   #12
Giles, I wish you success in your endeavor.
Thank you Starter! I had been helped many times before :-)
But unfortunately, GA it's kind of far from SoCal.. hopefully someone that lives closer sees this message
PS: Regarding you new belt.. did you measure next to the old belt? There is a possibility that the new one is not the same length
Old 09-19-2021, 01:34 PM   #13
Done the belt at least 6 times on various Box's without encountering the issue you're experiencing.
It sure sounds like you don't have the correct belt. Only other thing is your tensioner pulley isn't being moved far enough. Have you put the old back on? If it fits, its gotta be the wrong size on the new one.
Old 09-19-2021, 05:28 PM   #14
Agreed, either you're not engaging the tensioner properly or you have the wrong belt
I'm in south central KY but ATL is an 8nhr drive . You're not headed toward lake Cumberland by chance are you?
Old 09-20-2021, 05:01 AM   #15
I/m sure the old belt has strtched a bit over the years.
The tensioner pulley I don't want to break... I 'tension it so that it actually is touching the pulley next to it.
I ordered it from Pelican... so I'll reach out to them.
Thank you.
Old 09-20-2021, 05:38 AM   #16
2003 S, Arctic Silver, M6
paulofto's Avatar
There are 2 different belts, one for cars with A/C and another without A/C.
Old 09-20-2021, 07:53 AM   #17
It's the AC belt. Ughhhhh.
It's not earth shattering. The old belt is back on... working fine... but preventative maintenance calls for it.
