Old 09-08-2021, 06:11 PM   #1
porschefan76's Avatar
Hi kbod,
According to Wayne in his Projects book, page 38, Boxster 2001 (2.7 Liter and 3.2S):
(4th bullet)
"To install a Carrera 996/997 3.6/3.8 engine or a 2003-2008 Boxster/Cayman engine into one of these cars, you need to purchase a new 7.8 DME and then slightly modify the pinouts on the DME connector. In addition, you need to modify the Boxster engine wire harness, as the camshaft position sensors are located on the opposite ends of the engine than on the five-chain early motors. All of the systems on the car should work normally with one exception - the cruise control will not work properly with the later 7.8 DME unless you upgrade your ABS system as well (swap out the ABS controller and connector.)"
Hope that helps.
porschefan76 is offline   Reply With Quote
Old 09-08-2021, 08:10 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
There's a discussion on Renntech.org in which "xr_guys" posted a link to a spreadsheet of the DME 7.2 and 7.8 for comparison. You probably need to register for the forums to access the spreadsheet, but here's the link to the discussion: https://www.renntech.org/topic/51783-boxster-dme-72-to-78-transplant/
Old 09-09-2021, 01:30 AM   #3
Originally Posted by porschefan76 View Post
Hi kbod,
(4th bullet)
Hope that helps.
Do you know what is involved with a dme swap? Immobilizer system, harness, coding, etc… I live in Orange County California so getting the car to pass smog check is also a big deal, and I don’t want to break the bank too bad
kbod is offline   Reply With Quote
