Old 08-27-2021, 12:44 PM   #1
Climate stuck “off”
I was detailing my car and after that the climate control is stuck on “off” and no buttons seem to change anything, only thing I can think of is that liquid from the detailing spray made its way inside the buttons, any tips? I did just re do my dash and console in carbon but the ac never came out and while I was doing that I fixed the foam missing form the flaps and it worked then
Escott1622 is offline   Reply With Quote
Old 08-27-2021, 01:42 PM   #2
I would give a try of just unplugging it and plugging it back in to see if that does it.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 08-27-2021, 04:06 PM   #3
Hair dryer on warm/low…….
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 08-27-2021, 04:17 PM   #4
Had the air compressor on low spraying into each one actually
Old 08-27-2021, 06:17 PM   #5
The unit is surprisingly easy to disassemble/reassemble. You probably got liquids plastic between the button as and contact points. I would pull the unit out, disassemble, and clean all contact points. I've done this a few times installing new lcd screens (and then reinstalling them right side up lol) so id be happy to help if you have any questions while doing it.
Sent from my SM-G970U1 using Tapatalk
Old 08-27-2021, 06:50 PM   #6
I found a new(used) working one 10 miles from my house for 60$, ill try to clean mine but i have a backup, ill update as i go
Old 08-27-2021, 07:18 PM   #7
Did you check your fuses????
Old 08-27-2021, 07:23 PM   #8
Rookie mistake... i popped the fuse for my windows when putting things back together, for some reason i didnt think it would be a fuse since its powered on, ill check on that.
Old 08-27-2021, 07:29 PM   #9
Which fuse? I see E7 7.5 Air Conditioning System is this all?
Old 08-31-2021, 07:10 AM   #10
Mine went all crazy after a local car wash sprayed a bunch of cleaner/shiny stuff all over my center console a year ago. This after I told them not to spray anything on the interior...but after cleaning and drying overnight it was fine. Had to replace the LCD recently but I don't think it was related since the screen was 20 years old and probably due for replacement. Not too difficult or expensive.
dsallean is offline   Reply With Quote
