Old 08-26-2021, 03:53 PM   #1
you don't see much talk on those going bad unless you find green chunck's of rubber in either the oil filter or the oil pan as I understand it..I have to pull my engine this fall aswell. for the same job/inspection,...plus you can test those units with a 9 volt battery,.Ive never done it but there is a write up on it..! Frank
flmont is offline   Reply With Quote
