Old 11-13-2024, 01:50 PM   #1
Seeking Covertable Help
Hi
I'm trying to solve a convertible function issue. When closing the convertible the top gets nearly closed and then the motor reverses direction for a half beat then reverses again. I think the reversal happens when the convertible frame switch closes. Everything looks to be the right part number, in good shape and installed correctly. I'm wondering the relay is functioning correctly...
Anyone in the Tacoma Washington region willing to allow me to use your relay to test in my car?
Anyone else had this type of issue? I can't seem to find a replicated occurrence. The pic attached shows where the motor reversal happens
Joe
jcnichols253 is offline   Reply With Quote
Old 11-14-2024, 06:52 AM   #2
Could you fix that first please?
Did it work before you swapped parts?
Long shot, but it could be the microswitch inside the planetary gear. https://www.pelicanparts.com/techarticles/Boxster_Tech/BODY_Convertible_Top_Gear_Replacement/BODY_Convertible_Top_Gear_Replacement.htm
997_986 is offline   Reply With Quote
Old 11-14-2024, 12:25 PM   #3
The top has never worked under my ownership (3 months and counting). When I got the car all of the motion related drive mechanisms were in a box in the trunk. I've re-installed everything and gotten it function 98% correctly. Its this last 'closing' function that trouble some.
This is the 97-99 version. There aren't any switches in convertible transmission.
btw, that location you circled is as designed, just look extra curvy based on the photo angle.
Old 11-14-2024, 06:33 PM   #4
There is a table with what the motor with do based on the micro-switch states. Can't find it but will look for it. Seems like the switch for the clamshell it being depressed before the top closes? Perhaps the arm for from the transmission to the top needs to be extended? I'd disconnect the arms for the shell and carefully try to shut the top (making sure not to drive the transmissions too far).
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
