Old 08-10-2021, 08:16 AM   #1
Died on Highway
Well, technically the car didn't die. Engine revs fine. Clutch shouldn't be issue either, as it's only 18 months old...
It goes into gear, but won't move forward. I heard a pop sound - maybe I missed a shift?? - but I've missed shifts before over the years and never had this happen. It just won't move forward.
Thoughts??
safesaxbdd is offline   Reply With Quote
Old 08-10-2021, 08:42 AM   #2
Shift cables at the transmission?
dsallean is offline   Reply With Quote
Old 08-10-2021, 09:14 AM   #3
Thoughts??
What were you doing when you heard the pop sound?
Were you shifting gears????
Pushing clutch pedal in???
So it will not move as you let the clutch out correct????
Old 08-10-2021, 09:30 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
At least once a year someone on the Forum has their axle bolts come out or break. Check if the axles are still connected to the transmission.
Old 08-10-2021, 11:35 AM   #5
2002 Boxster S
When I got under my 2002 S for the first time the CV joint retaining bolts were so loose I was able to turn them with my fingers. I now get under the car remove the reinforcement plate and check all bolts every year.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is online now   Reply With Quote
Old 08-11-2021, 06:14 PM   #6
gabedrummin's Avatar
Had an axle shaft break once . Goes nowhere.
gabedrummin is offline   Reply With Quote
Old 08-11-2021, 07:22 PM   #7
Do you have a picture?
mikehkang is offline   Reply With Quote
Old 08-12-2021, 06:13 AM   #8
Tailwind's Avatar
+1 on the busted drive axle
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 08-26-2021, 10:52 AM   #9
Thanks, all! Sorry just logging back in here. Yep, it was the CV joint that came undone from the tranny - and it was JUST replaced - the mechanic who replaced it clearly didn't secure it properly. All resolved finally.
I'm assuming if one of the drive axles (there are 2 on the boxster) loses connection, the other does as well? Anyone know?
Old 08-26-2021, 11:22 AM   #10
If it is an open differential, yes.
