Old 07-26-2021, 04:02 AM   #1
flouese's Avatar
Seat recline only
Several weeks ago I took my seats apart to put new LSEAT skins on them. Put them back together, however, when I went to adjust the seat back, it reclines only. When I put the seats back together, I found a tiny spring that belonged in the recline switch. I put it back where I thought it belongs, but now I'm guessing it's not where it should be. Where did I go wrong? Hard to drive with the seat reclined to where it currently is. PLEASE HELP
99 base.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 07-26-2021, 05:05 AM   #2
KevinH1990's Avatar
I suggest that you check whether the part of the seat recline switch you touch with your hand is positioned over the nubs on the electronics part of the switch. One of the holes on the black plastic part may not be aligned over the nub that actually operates the switch mechanism.
Old 07-26-2021, 06:29 AM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Can you check/compare it to the opposite side seat?
