07-24-2021, 09:24 PM
Aftermarket seat mounting
As with all these projects, the devil is in the details...
Im down the rabbit hole of new seats (no definitive plans yet but I'm in love with the braum falcon x series) and I pulled out the passenger seat tonight just trying to get a feel for the mounting system and what I need to be looking for.
Here's my question - assuming that most of these seats don't recline and aren't mounted on sliders, how the hell do you get to all 4 bolts to mount the thing to the floor? It seems like sliders are mandatory - or are aftermarket seats just that much shorter front to back so all 4 holes are exposed at the same time?
07-25-2021, 06:10 AM
They would have to slide. How else could someone who was 5'2 reach the pedals vs someone who was 5'9? Otherwise the seats are going to be in a static position.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
07-25-2021, 08:33 AM
This is my first time messing with seats so I only know what I've read, but I thought that a lot of racers mounted seats in surely to the floor bracket at their desired position to save on weight and to drop an extra 1/2" for roll bar clearance. I don't think that I've touched my seat slider since I've purchased the car so I don't really care of I have them, and I like the idea of dropping down closer to the floor. But i can't figure out how you could possibly get away with that considering the location of the bolt holes
07-26-2021, 09:45 AM
my fixed sparco seats are on a planted mount, which raises them up a it. The front bolts are easy to get to but the rears are a real ********************. I'm sure you could find a way to make the situation better, but I've got the seats where I want them so they don't come out often.
07-26-2021, 03:23 PM
That's what i figured - probably a blind reach with a ratchet and extension
I bought some 370z seat brackets just to compare and I struck me how much longer distance there is between the front and rear mounting bolts. That would probably help in this situation but would still be a pain I'm the ass with a fixed back seat.
I think what I'm gonna do is use the factory mount and slider on my oem seats to bottom mount a new seat. I think I figure out last night how to unbolt them without drilling any rivets.
I'll keep everyone posted.
07-30-2021, 04:35 PM
IIRC I have seen a post here regarding limited torque cycles on the stock seat mounting bolts. Do have a search....
986 00S
07-30-2021, 05:39 PM
They use those special e style heads, so that means Porsche doesn't want the reused. I was planning on replacing them with new 10.9 grade when all is sorted. Thanks for the heads up!
07-31-2021, 05:30 AM
I drilled and tapped the holes out to 1/2". Rock solid now
07-31-2021, 10:24 AM
Did you enlarge the existing holes or drill new ones altogether?
08-02-2021, 07:11 PM
08-03-2021, 05:31 AM
Enlarged existing holes
08-03-2021, 07:40 AM
Here is my solution to floor mounting the seats, and I think it also has some info about the issue that you mention:
ARP accessory studs for race seat mounting
08-03-2021, 02:17 PM
Originally Posted by steved0x
Thanks for posting that link, very interesting stuff. I am a bit confused though, how do the studs help you? By eliminating the guess work of lining up the holes?
08-03-2021, 04:29 PM
In the back, I have to start the bolts by feel (can't see) in a very tight space while the seat pushes against the center tunnel,, where with the studs, the seat drops right onto the rear studs and I just have to thread the nut on, also by feel in a very tight space, but easier :-)
08-04-2021, 06:57 PM
That makes sense, I appreciate the suggestion! Have you had any problems with those studs loosening up in the odd bolt-cut threads?
08-04-2021, 07:01 PM
Next question - out of sheer ignorance, again...
How rigid are fia certified seats?
For ****************s and gigs a bought a pair of nrg frp300 seats. Very nice looking but I was surprised by how flexible the main back and especially the shoulder wings are.
Before everyone flips out, I be don't plan on keeping the nrg seats. I'm talking safety seriously and will ultimately install fia certified seats. This is just a test fit of sorts.
08-04-2021, 07:08 PM
A set I sat in that were in a miata (dont know brand/model) I thought the same about the backs & wings but they must of passed fia requirements cause they had the tag on them. I wasn't much of a fan cause I just couldn't get comfortable in them.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
08-04-2021, 07:18 PM
Thanks for letting me know, that's helpful
I'm not crazy about the comfort of these seats. The oem seats are def more cushy and these are a bit too narrow around the middle of the back where my dad-bod chest starts to widen out. I'm hoping that the braum seats are better in this regard.
08-04-2021, 08:25 PM
Find someone with a mid 80's 911 or 944 that has sport seats. Talk about comfort and great on the track
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
