Old 07-17-2021, 01:33 PM   #1
Old Car Guy
vetman's Avatar
Speed Bleedeers
I couldn't find the specs for the Speed Bleeder for the 98 Boxster. the company website didn't list the 98 so I called the company and I was told the correct part number is SB1010S. Same as for a 911.
I've used them many times before and was always satisfied. I can't get anyone to walk 100' to the garage and pump the brakes. Yes, I bought the pressure bleeder also.
Ray in Ellenville, NY
Old Car Guy
vetman is offline   Reply With Quote
Old 07-17-2021, 01:43 PM   #2
Another person and or the other fancy stuff is great.
But all you really need is a piece of broom handle cut to the right length.
Pump the brake up then wedge the broom handle between the brake pedal and the front edge of the seat. Open the bleeder for a second or two close the bleeder repeat.
I have done it that way for 50+ years. Never had an issue.
Old 07-17-2021, 03:41 PM   #3
Old Car Guy
vetman's Avatar
I had a fancy spring loaded pole from Griots years ago to bleed the brakes and clutch. I like the speed bleeders. After just doing IMS, clutch and engine mounts on a car I haven't driven yet, this is not a big deal. I will probably replace the brake lines with stainless. this car is almost 22 years old and was cared for but certainly not pampered.
Old Car Guy
Old 07-17-2021, 04:42 PM   #4
JayG's Avatar
Or get a power bleeder and then you don't need a stick
Old 07-17-2021, 04:55 PM   #5
Or get a stick and then you don't need a power bleeder.
And sticks are cheaper.
Old 07-17-2021, 06:23 PM   #6
I used to see a lot of guys using these on 944's that would swear by them. Personally I'll still with my motive bleeder, always gets the job done quick.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 07-18-2021, 05:54 AM   #7
JayG's Avatar
To each his own. Kind of hard to use a stick to do a full brake line flush
With a power bleeder, you can jack the car up, take off all 4 wheels and bleed all corners very easily. Not a very expensive tool you will use many tines on a Porsche and other cars.
Lots of reasons most shops use a power bleeder.
Old 07-18-2021, 07:09 AM   #8
1999 Boxster 5 spd.
I just bled the brakes on my '99 after removing the calipers for paint. I bought the power bleeder and new speed bleeders. I guess in reality, you don't need speed bleeders if you are using the power bleeder but I wanted to replace the bleed valves anyway. It all worked splendidly and I had the system bled in just a few minutes.
99 Boxster 5 spd, Arctic Silver
Dayton, Ohio
Huey is offline   Reply With Quote
Old 07-19-2021, 05:42 AM   #9
JayG's Avatar
Yup. Power bleeder is the way to go
