Old 07-13-2021, 11:34 PM   #14
Like what others said. Use Porsche AOS. Clean out the oil from the C shaped hose before throttle body, throttle body and intake tubes. Pull one of the spark plugs. if there is oil on it, you can clean all with cleaner. The rest will burn off.
If its still smoking badly like before after all these work, you have oil in the cats. Try to find used cats.
moosport is offline   Reply With Quote
