05-28-2021, 12:01 PM
#1
They are plug and play as long as you are fine with fixed manual adjustable lights. I have them that way in my 98. If you have to have the auto leveling and high beam fill then you will have to buy controller, suspension linkage and wiring.
05-28-2021, 12:04 PM
#2
What do you mean by fixed manual adjustable light via auto levelling and high beam. I won’t be doing a lot of night driving and just want to replace my halogens because the reflectors are cracked.
05-28-2021, 12:13 PM
#3
OK, so 911monty confirmed what I suspected.
see this vidieo.
https://www.youtube.com/watch?v=zeQfR5Q2KlQ
To remove the headlight - it just comes out, but this one, equipped with Litronics, has an additional plug that is used to adjust the headlights.
Many HID systems had autoleveling - if the car is empty, the lights will light up the road fine, if the car gets heavy, front may lift up and then they light up too high. Hence, autoleveling will adjust them down.
Can be done manually or, if you never drive with extra load (actually, quite hard to do in Boxster) - never touch it again.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
05-28-2021, 02:53 PM
#4
Ok thanks PLP. So basically because my car was originally fitted with the Xenon assembly I won’t have that extra connector?
What about the washer at the corner? Would that be an issue?
Forgive me for my ignorance. I am new to this world.
I may have been able to source a pair of Xenon headlight assemblies for a reasonable price so this is why I am asking. I don’t want to purchase it and then it doesn’t work. As long as it works I am ok with that.
see this vidieo.
05-28-2021, 05:22 PM
#5
see this vidieo.
Ok so the only thing that won’t work is the auto level feature. How do you manually adjust?
