Old 05-13-2021, 11:19 AM   #1
99 986 Stalling when A/C cuts on
Hello,
So I've done a ton of work to my Boxster but now have a new problem. It started when I replaced the charcoal canister and fuel vent valve. Car would start up and run perfectly but if I shut it off after it was hot it would have problems starting. I took it to mechanic and they diagnosed an air leak and corrected. I went to pick it up and it was perfect, until I turned on the A/C, then it stalled out. It seems as though my problems began when I was trying to chase down the evap leak and replaced those items, could they be causing the new issue? Thanks for the help
Boyantonwl is offline   Reply With Quote
