Old 04-27-2021, 11:46 AM   #1
Garage Floor Mats
Hey all,
I'm a relatively new owner and this forum has been incredibly helpful so thanks in advance.
I've just moved house (a rental) and the garage leaves a lot to be desired.
The place is on a steep hill and there is some kind of ground water leak into the garage which makes the floor permanently wet. Because of this the concrete floor is breaking up and the whole thing is a wet, stony slurry.
I'm looking for a garage floor mat product that solves this problem.
Ideally its raises the car up off the wet floor whilst allowing the water underneath to evaporate or run out of the space. I'm in LA so hoping the warmer weather helps keep everything dry.
The water is high in minerals (leaves white lime deposits) and will break down rubber fairly quickly so i'm guessing the mats also need to be pretty durable.
Anyone dealt with this before?
mmackie is offline   Reply With Quote
Tags
floor mats , garage
