Old 04-14-2021, 12:44 PM   #1
Thanks for the replies and for taking a look at the video '78! I agree with measurement points. I picked up a caliper tool and will measure off some hard points moving forward. It will soon come to disassembling all the pieces to get a better look at everything and those notches.
I have no idea how that ball mount came unscrewed from the passenger side transmission. It went back together and the threads were not stripped- it has held up in the operations since. I'm baffled as well. However, in making the adjustments in that video I was not able to pop the push rod off the ball end on that side and had to unscrew it completely. Maybe if the rod end does not pivot freely over the ball it loosens with time?
986andmx5 is offline   Reply With Quote
Old 04-21-2021, 04:57 AM   #2
When stopping to look at clearances during the entire operating sequence I saw there was contact between the transmission V when near vertical and the metal lip under the slide rail on the driver side (likely damaged/disfigured during initial trauma). I was able to bend the lip to alleviate contact, but this did not help with the greater issue of the driver side clamshell support digging further back into the weather stripping than it should when the V is near horizontal.
Something is either bent that I am not seeing- very possible even after much time spent examining all the pieces. And I should remove the cover to the transmission on the driver side to get a better look at it for damage/operation, along with making sure the 3 nuts that hold it in place are still snug.
Old 05-17-2021, 06:33 PM   #3
At this point I have replaced almost every component of the driver side clamshell support system with parts off another Boxster. For whatever reason, the arm on that side still over extends aft when operating through the top-down sequence and is not level with the passenger side throughout. Both transmissions are in sequence. I checked that the 3 driver side transmission attachment nuts were snugged and everything is secure there.
The parts coming off the rear of the transmission V all rotate around a fixed point. All components from that point are in good condition/not bent and I have no ideas as to why the driver arm is not operating as it should (seen at 3 min mark in link). The V itself and ball mount were even replaced to rule them out. Any thoughts?
https://www.youtube.com/watch?v=2t0BlUGbKdk&t=6s
Old 06-19-2021, 04:58 AM   #4
This issue has me baffled and slightly demoralized that I will be able to find a solution. I took everything apart today to get a look at the studs that the transmission attaches to and everything looked fine.
I torqued it back together by spec, alignment was still showing true by the notches in both transmissions and yet still having the same issue- aluminum clamshell support arms are uneven throughout travel and the driver side hyper-extends into weather stripping when it reaches it's most rearward position.
At this point I am considering converting to manual operation if that would fix my issues.
Old 06-19-2021, 08:27 PM   #5
Did you take the transmission apart and check the gears. If the nylon gear is broken or missing a few teeth that can happen. Did you use a drill motor to check the cable operation.
MrBen is offline   Reply With Quote
Tags
clamshell , convertible top , tonneau cover
