Old 10-31-2006, 04:16 PM   #1
how come the spoiler only goes up halfway?
i would push the button and it only opens up a little bit.
i was only able to get it fully open once, and now it only goes halfway.
anyone else has this problem?
my cardomain/pictures page
Old 10-31-2006, 04:47 PM   #2
Interesting, do you get a Spoiler lite on your dash after it stops halfway? if not then i dont think its a mechanical issue.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 10-31-2006, 04:54 PM   #3
no light whatsoever
i was thinking about putting a decal there, ad wanted to measure it and whatnot, and icant get it to go all the way up now
Old 10-31-2006, 05:02 PM   #4
well lets see, Did you know that the Switch is a one-touch to get it to raise, but to lower the spoiler you have to hold the button until the spoiler is completely down...If you only held it part of the way, then the spoiler is considered partly open still and i think if you press the UP switch, itll only raise while you hold the button.....
Try Holding the Down button for more than 7 seconds to insure its all the way down with ignition in the ON posistion, Once your are 100% positive its down, then press the up button and quickly get out the car and watch it raise to insure its raising all the way up.
Carlos J Cazares
Old 10-31-2006, 05:04 PM   #5
bmussatti
Posts: n/a
djomlas, you're kinda young to be having issues like this!!
What if you "hold" the button vs. "push" the button? Does it go up completely when you reach the proper speed...aprox 73-74 MPH?
Old 10-31-2006, 05:11 PM   #6
i tried everything, holding it forever, holding it for short period of time, putting it down and holding for a period of time to make sure its down and then try up again, i tried everything, still...ends up being halfway up raised.
and as for above the 75 or so, well i really cant see the thing so i have no clue
Old 10-31-2006, 05:20 PM   #7
bmussatti
Posts: n/a
Do you have a camera phone? When you are driving 73-75 MPH (witht the top down) raise your hand in the air with the camera phone pointing back at the rear spoiler...and take your picture. Be careful!
If I were an attorney, I'd list some type of disclaimer. So let me repeat myself...please be careful!!
Old 10-31-2006, 05:26 PM   #8
hmmm.... 75 is just a little bit over the speed limit
ill give that a shot and well see
Old 10-31-2006, 05:46 PM   #9
Viagra?
...sorry
Marc Gelefsky
02 996 Carrera Coupe 6 Speed Aero
86 911 Carrera Targa
http://forums.rennlist.com/rennforum...tar14266_4.gif
EX-88 951, 87 951, 86 944na, 85.5 944na 00 Audi S4..01 Boxster S .etc..etc
Marc Gelefsky is offline   Reply With Quote
Old 10-31-2006, 05:47 PM   #10
where do you guys think i should feed the car viagra?
Old 10-31-2006, 05:50 PM   #11
Well if they made viagra in sopository form then i would say the tailpipe, but since they arent, pop it in the drivers side intake scoop.
Carlos J Cazares
Old 10-31-2006, 06:31 PM   #12
All kidding aside, the spoiler uses a high current motor with a transmission. It has 2 relays which control it, both located in the rear Relay Block in the trunk. Relay #3 is the Spoiler Extension Relay and Relay #9 is the Spoiler Retraction Relay. You read the Relay Block L-R 1-6 top row, 7-12 bottom row. The fuse for this circuit is D7.
I suspect your switch or the relays are your problem. Try swapping the relays to see if you can get the problem to reverse itself. This will confirm that the Extension Relay is the problem. You can also remove the switch and jump it, but this is a little more complicated, so try swapping the relays (or just reseating them) first. Relays do tire when about to go, so the extension relay may have bad contacts which release when it gets warm from use. Hope this helps...
Happy Motoring!... Jim'99
Old 11-01-2006, 03:45 AM   #13
i tried the 2 relays in the trunk, switched them around...same situation
Old 11-01-2006, 09:49 AM   #14
Ooh, that's not good. Next on the list of possibilities would be the Motor. This motor is attached to a transmission. I'm thinking that perhaps a tooth is broken, dirt or debris is stopping it, or some such. I would suggest that with the aid of an assistant, you try to raise the spoiler, with the assistant activating the switch and you gently pulling the spoiler up, not going all Ahhhhnold on it, just giving it some gentle help. This may work you past any issues.
If still no-joy, then I'm afraid that you're looking at taking the system apart, not really difficult, but fairly involved as you must essentially disassemble the trunk, latch, etc. to get at it. I probably have the procedure available if you PM me your email addy. Hope this helps...
