Originally Posted by djomlas
i tried the 2 relays in the trunk, switched them around...same situation
Hi,
Ooh, that's not good. Next on the list of possibilities would be the Motor. This motor is attached to a transmission. I'm thinking that perhaps a tooth is broken, dirt or debris is stopping it, or some such. I would suggest that with the aid of an assistant, you try to raise the spoiler, with the assistant activating the switch and you
gently pulling the spoiler up, not going all
Ahhhhnold on it, just giving it some gentle help. This may work you past any issues.
If still
no-joy, then I'm afraid that you're looking at taking the system apart, not really difficult, but fairly involved as you must essentially disassemble the trunk, latch, etc. to get at it. I probably have the procedure available if you PM me your email addy. Hope this helps...
Happy Motoring!... Jim'99
