Old 03-08-2021, 07:10 AM   #1
Question Help! I jammed my top transmissions?
So long story short is that I was replacing the entire soft top with another one. It's just 3 bolts on each side and you disconnect the soft top from the V levers. I did everything fine except for when I was putting the clamshell back down (no top attached) I believe I held the button down for too long and my clamshell was stuck (could hear the motor but no movement). I somehow disconnected the clamshell from the v levers that were locked in place to get it free but now when I use the button the motor sounds fine but the 2 levers dont spin. Does anyone know how to fix this?
CharlesE is offline   Reply With Quote
