Old 03-06-2021, 09:04 AM   #1
Question Oil cap looks moist. Should I be worried?
I'm changing the oil in my 99' boxster and I noticed taking the oil cap off was hard. Then when I got it off there was a weird moist oil residue on the top of the filler and the cap looked wet. Should I be worried?
CharlesE is offline   Reply With Quote
Old 03-06-2021, 09:27 AM   #2
Also the oil that came out looked fine. The dipstick looked normal. But I think my AOS might be going bad.
Old 03-06-2021, 09:40 AM   #3
911monty's Avatar
How do you drive your car? Lots of short trips that barely get engine warm? Looks to me like engine not getting hot enough to cook off water vapor. As far as AOS get a manometer and check.
Old 03-06-2021, 09:44 AM   #4
Just came from a long drive on the highway so it usually always gets up to temp. Is it possible the cap is going bad in letting moisture in.
Old 03-06-2021, 09:52 AM   #5
911monty's Avatar
The cap would show as an air leak. As engine cools water will condense inside the case. When you say usually always gets up to temp do you mean you get it to 180 deg and drive for 20 min or more or just gets there and then shut down.
If you are not short driving it then you may have other issues.
Old 03-06-2021, 11:49 AM   #6
If your AOS was going bad, the sump vacuum level would be too high, which would help get rid of the moisture. Your problem lies elsewhere.
Old 03-06-2021, 12:37 PM   #7
Not enough driving, or perhaps too many short trips..?
Old 03-06-2021, 06:04 PM   #8
I'm in this camp
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 03-06-2021, 07:14 PM   #9
Possibly, but the water could be coming from an internal source as well.
Old 03-06-2021, 07:28 PM   #10
I drive it alot and i dont drive slow so i know its gets warm enough. I did notice a really slow coolant leak but I dont know where its coming from I just see the level drop every month or so. Could this be a factor?
Old 03-08-2021, 05:23 PM   #11
Bad O-rings on the heat exchanger could be the cause for this issue as well..?
Tags
oil cap , residue
