Old 02-23-2021, 07:29 PM   #1
LN engineering says their IMS solution is good for about 75k (but that depends on which model you get)
I would say you can swap it out at the NEXT clutch change, considering it was just done. I can only assume you are at 50k miles, so you are good for a little while considering the IMS has only 30k on it.
However- Definitely check your oil at every oil change for metal particles.
solo118 is offline   Reply With Quote
Old 02-24-2021, 06:10 AM   #2
Veteran & Boxster Padawan
Farmlifer's Avatar
Thanks you very much for the feedback - yes, 51K miles with clutch just replaced and will monitor oil ✅ until next clutch /IMS R&R
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
Old 02-24-2021, 07:23 AM   #3
The IMS Solution is permanent and has no service interval.
The IMS Retrofit is 6 years or 75,000 miles.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
