Old 06-18-2022, 04:02 PM   #61
KevinH1990's Avatar
What? Dont understand this (and never use something made to be used in a house in a car. lol).
Definitely not one of my better ideas.
If the CD-player bracket is attached to the bulkhead like the Hase amp, it looks like the OEM technology uses a piece of rubber with a hole in the middle to receive a fastener. The rubber piece has a groove in the middle of its outside edge. The two outer lips are larger than the opening in the sheet metal and the rubber piece is wedged into place.
I may have trouble hunting down the OEM part and will need to develop another option. The bottom of the CD-Player bracket has a large tab that inserts into a slot in the frunk floor. You can see it at the bottom of this photo:
That holds it fairly securely especially since the amp is small and mounted low. I may not need the upper fasteners.
Old 06-19-2022, 01:27 AM   #62
WALDMEISTER
BRAN's Avatar
Excourse:
I recently noticed not so much "umpf" from my audio system. Luckily the faulty part gave me a hint, where to search. I could barely tell the difference, but something wasn't right. So I pin pointed the missing audio power via the setup/equalizer. Long story short: I had a bad ground crimp connection for my sub. It did not supply enough "juice" for its full potential and was slowly giving in.
I did a professional crimp job this time and VOILA...the sub is back at its full potential.
Easy to solve, but not obvious. Luckily, I checked the ground wiring first.
Old 06-19-2022, 01:37 AM   #63
WALDMEISTER
BRAN's Avatar
Hey Kevin, do you mean these grommits? They are all over the place
https://www.amazon.de/XCOZU-Gummistopfen-Karosseriestopfen-Elektrischer-Dichtungsringe/dp/B095GS9917/ref=sr_1_9?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3 %91
Old 06-19-2022, 05:09 AM   #64
That amp is small enough to fit inside the bulkhead next to the battery. That's where mine lives. It's a tight space in there so no mounting required. Just position it where it's happy and move on.
Old 06-19-2022, 09:52 AM   #65
[QUOTE=KevinH1990;647206]Definitely not one of my better ideas.
That holds it fairly securely especially since the amp is small and mounted low. I may not need the upper fasteners.[/QUOTE/]
The rubber pieces that secure the bracket to the bulkhead are called 'well nuts'. They are available at most decent hardware stores.
Old 06-19-2022, 11:07 AM   #66
KevinH1990's Avatar
Excourse:
I solder and shrink tube my connections. I haven't had any trouble with connections coming apart. On this project, it was difficult to obtain access to the spot where I needed to solder the speaker wire connections. With some minor contortions I was able to make strong solder joints.
I've had to solder together some heavy gauge wire for other projects including this one on my 2005 Mercedes C230: https://mbworld.org/forums/c-class-w203/820479-memory-seat-retrofit.html
I have the Porsche to be less complicated to work on than a newer Mercedes.
I found that this device was indispensable for applying sufficient heat to the joint:
I need to exercise caution when using this to avoid setting anything on fire.
Old 06-19-2022, 11:12 AM   #67
KevinH1990's Avatar
Thanks - Now I will know exactly what to request at the hardware store.
I hope that no one objects to me working out the details of my projects on the forum. I think I start with 70-80 percent of the knowledge I need to complete a job and it seems like someone on the board always comes through with the remaining information.
Old 06-20-2022, 07:35 PM   #68
Don't rework but there's a reason that wired connections are not soldered in cars, or ships, or planes......vibration.
The weak point of your connection becomes the point the wire and the soldered connection meet as the wire is typically not secured. Again, not suggesting going back but just understand that a well crimped connection is best in transportation environments.
Old 06-21-2022, 06:10 PM   #69
KevinH1990's Avatar
I did a search on "Should I solder car audio connections?" I reviewed a number of posts on several forums. Most of the posts indicated that crimping with a high-quality crimp tool was a good method. There were some posts advocating for solder. The only caution I saw about soldering was a warning about putting too much heat near a factory connection that was soldered.
I note that the OEM woofers have a spot of solder connected the wires from the voice coil to the terminals:
For what it's worth, I've also seen technicians on auto restoration shows such as Wheeler Dealers use soldered connections including Ant Anstead soldering connections after he swapped an alternator in to replace the generator on a TR4.
I am concerned that a soldered wire is more brittle and could crack. I'll research more thoroughly before my next project.
Old 06-22-2022, 06:44 AM   #70
I would NOT solder the wire to speaker connectors. However, many people including me, will solder lead wires into "crimp" connectors and then heat shrink tube for a professional look. Def not necessary so long as you make a solid crimp.
Good luck
"Cool Prius!"
- Nobody
Old 06-25-2022, 06:37 PM   #71
Dont put an amp by the battery. Bad idea. That area isn't sealed to the outside and is where water is designed to get in.
Yes, a soldered connection will absolutely crack. Depends on how good it is, the solder & time. Just do a search for 944 Cold Solder and read.
Dont over think this or over engineer it. It's just an amp and it's just a bracket. It's not a competition car for audio after all. Keep it simple and things will be just fine.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
