Old 01-21-2021, 05:13 PM   #1
Failed turn signals
Just took delivery of an '03 base Boxster. 1 week in, the turn signals quit working. Stalk moves, no lights. Hazard switch will not depress.
Also, where can I find a chart for the fuses?
Melsblueboxster is offline   Reply With Quote
Old 01-21-2021, 05:59 PM   #2
hazard lights are also turn signal. I would address the hazard switch problem first. Fairly simple to replace. With cluster cover removed it just snaps in and out. Quite possibly the hazard switch is causing the turn signal problem.
obthomas is online now   Reply With Quote
Old 01-22-2021, 08:53 AM   #3
2003 S, Arctic Silver, M6
paulofto's Avatar
Mine has a folded fuse chart in the fuse box in the drivers footwell.
Old 01-22-2021, 07:41 PM   #4
Found the problem with the turn signals. Hazard switch was stuck. Seems to be okay now. Next problem- front trunk won't open. Worked fine upon delivery, had it open half a dozen times, now won't open. How do I get in there?
Old 01-24-2021, 07:16 AM   #5
1998 Boxster Silver/Red
Press the hazard button.
1998 Porsche Boxster
Old 01-24-2021, 07:41 AM   #6
piper6909's Avatar
Haha Starter!
Mel, I think Starter meant to do a search for "emergency frunk release" You'll find lots of posts on the subject.
Good luck.
2010 Subaru Forester
piper6909 is online now   Reply With Quote
