Old 12-11-2020, 07:45 AM   #1
A Menagerie of codes
After thinking I had things totally squared with AOS and EVAP and about two weeks of happy motoring, she runs rough and threw a number of codes;
P1126
P1133
P1130
P1128
P0442
Does anyone see and commonality that might help me?
David
Luckyman01 is offline   Reply With Quote
Old 12-11-2020, 08:48 AM   #2
P1126
P1133
P1130
P1128
P0442
David
What year is the car?
How many miles?
Any modifications?
If you have an early car with the 5.2DME then the P0442 CODE is for a micro leak in the fuel tank ventilation system.
That issue could cause the other codes as they are all O2 Sensor related at low RPM.
If your car is newer and running the 7.2DME I haven't found the P0442 code for it yet.
Porsche OBDII DTC codes are not always the same from year to year so it makes it tricky sometimes.
Old 12-11-2020, 09:13 AM   #3
2000S with 120K, no mods
David
Old 12-11-2020, 10:16 AM   #4
David
I don't find the P0442 code for a 2000S in my Bentley book but lets assume it is the same as the P0442 code for earlier year Boxsters.
You have done recent work on the AOS and the Evap system.
The P0442 is for a micro leak in the Fuel tank ventilation system.
Relates to the Evap system.
I believe all your other codes which are O2 sensor related are triggered by the micro leak in the fuel tank ventilation system.
So I would find and correct the micro leak problem first.
Then erase all codes and see how you go.
You may have not gotten something just right when you worked on the Evap system.
Or disturbed something when doing work on the Evap or AOS.
Let us know how you go I always like to know end results.
Old 12-12-2020, 07:55 PM   #5
Zzorro's Avatar
Blue62 is a good hand. Helped me lots when I was doing my O2 sensor changeouts.
I would swap out the gas cap 1st. Heard many times that solves a bunch of fuel related issues.
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
Old 12-15-2020, 11:21 AM   #6
Thank you Blue62
You sent me down the correct path, it was a short walk, I had intalialy discounted the gascap as I had just replaced it. However, I had fuelled up that day. The gas gap was cross threaded. Reinstlled and probem solved.
BTW, I see you are in Washington state, quite close by forum standards.
You have a friend at the beach.
