Old 11-27-2020, 11:03 AM   #1
flouese's Avatar
Retainer clip
How do you remove this clip from the forward most undercarriage splash guard? I searched the forum, google and YouTube already for an answer and couldn't find one. Loosing coolant from that area and need to fix it.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 11-28-2020, 06:55 AM   #2
jcp
Insert a flat blade screwdriver tip under the vertical tab hanging down from either end. Rock the tool toward the center of the clip and it will release the locking portion of the clip while pulling the end down and out. If the tab is broken off from previous removal, they can be a bit of an aggravation.
jcp is offline   Reply With Quote
Old 11-28-2020, 01:15 PM   #3
Will there be cake?
tonythetiger's Avatar
they pop right off from either side with a flat head. You can bend them back into shape if they get distorted, but they are also pretty cheap so I bought a few to replace any that break or bend really bad. Once you do one, you'll get how easy it is. :+)
