Old 10-19-2020, 08:46 PM   #1
996 Retrofits
Is 996 Retrofits still in business? I’m looking to upgrade my headlights and someone said that he is no longer in business. Would love some input on this and also what else is out there.
tekkron64 is offline   Reply With Quote
Old 10-20-2020, 04:54 AM   #2
Sorry can’t help with the actual question but in terms of other options for headlight upgrades I was going to go with these in the next couple months. They seem to have good reviews. Anyone have direct experience?
https://shop.redline360.com/products/spec-d-projector-headlights-boxster-911-996-led-drl-97-01-black-or-chrome
-tWv- is offline   Reply With Quote
Old 10-20-2020, 04:55 AM   #3
1998 Boxster Silver/Red
About 51,400 results (0.56 seconds)
https://www.facebook.com/996retrofits/
1998 Porsche Boxster
Old 10-20-2020, 06:02 AM   #4
A Porsche Guy
1PorscheBoxster986's Avatar
The last time I spoke to Ron was in July 2020. You can try emailing him at 996Retrofits@gmail.com. He should be in business.
1PorscheBoxster986 is offline   Reply With Quote
Old 10-20-2020, 10:03 AM   #5
JBauer's Avatar
I talked to him a few weeks ago and he's no longer building headlights. He took over his father's business and doesnt have the time to do them anymore. Too bad he was really talented.
Old 10-20-2020, 10:13 AM   #6
JBauer's Avatar
I'll I heard were bad reviews. LEDs burn out quickly and cant be repaired and the warranty is sketchy. That discouraged me from buying them. I built my own. At least if they break I can fix them. Not too hard to do and a lot less money.
Old 10-20-2020, 04:07 PM   #7
Now for the second question then. Who sells the parts or kits to update the headlights?
Old 10-20-2020, 06:17 PM   #8
JBauer's Avatar
These guys are the only company that sells a kit, that I know of, with the centering brackets needed to make panamera shrouds fit. They also sell just the brackets if you want to make your own set up. The kits around $300 US. Heres a link to a partial installation video.
https://youtu.be/5uAy3hwdc0Y
Old 10-21-2020, 06:08 PM   #9
Thank you. They are just over $300 now. They look pretty good after talking to them.
Old 10-26-2020, 12:32 PM   #10
Another question for everyone, what other retrofit kits are out there? I really need to do something about it over the winter. My stock halogens just don't cut it anymore.
Old 10-26-2020, 07:06 PM   #11
JBauer's Avatar
The link below is to the only company, that I could find, that sells a kit that comes with the centering brackets. They also sell just the centering brackets if you want to make up your own kit. They are needed to replace the factory bowls so the projector will be centered. If you dont care about a shroud you can mount any projector in the factory bowls.
Old 10-26-2020, 07:17 PM   #12
JBauer's Avatar
Left: factory bowl with generic xenon projector, not able to center.
Right: With centering bracket, about $30 if ordered alone, adds room for larger projector and Panamera shrouds.
Old 10-26-2020, 09:38 PM   #13
Thank you. I spent a good part of the day trying to figure out was needed to complete this project. This makes it that much easier.
Old 10-27-2020, 10:10 AM   #14
JBauer's Avatar
I found an old shroud that I forgot I had. If you want to go with factory bowl to start out with, this is a inexpensive ebay projector and a smaller shroud. Pretty easy to do if your just starting out. Stuck it in a old headlight to give you an idea what it looks like. Better than burnt lenses.
Old 10-27-2020, 01:13 PM   #15
Wow! Thanks for the input. I'm going to the junk yard in the near future and picking up a set of 986 headlights and will be working on retrofitting those. You have definitely given me a lot to think about on this. I'll keep everyone updated.
Old 10-27-2020, 04:02 PM   #16
Creativity goes a long way.
FYI: you cannot get these projectors anymore.
Old 10-27-2020, 04:06 PM   #17
OK. Route 66. You've got my attention. Have already you shared your new locale?
Old 10-28-2020, 12:20 PM   #18
JBauer's Avatar
Can that bracket for the smaller projector be purchased? I'm guessing you made it? Looks cool as hell.
Old 10-28-2020, 02:51 PM   #19
Ft. Leonard Wood, MO (Ozarks).
The PNW kind of bummed me out. Between shutdowns so strict that you couldn’t get a dentist appointment or even go to the beach, and the weeks of wildfires and smoke, I threw in the towel.
Thanks. The smaller projectors are LED and are mounted directly to the reflector bowl with two bolts and spacers to make them “float”. I don’t know how much you’ve seen, but I changed my headlights 5 or 6 times before settling on this one.
Old 10-28-2020, 05:29 PM   #20
JBauer's Avatar
[QUOTE=particlewave;
Thanks. The smaller projectors are LED and are mounted directly to the reflector bowl with two bolts and spacers to make them “float”. I don’t know how much you’ve seen, but I changed my headlights 5 or 6 times before settling on this one. [/QUOTE]
Heck of a job. I tried mounting through the bowl and they are so brittle I broke several. Thats why I had to go to the brackets.
