Old 10-12-2020, 04:25 PM   #1
amagalla's Avatar
Size of nut in the rubber well nut?
I'm looking for the size of the nut inside the rubber well nuts (part number 999-500-092-00) that hold the 2 side plastic trim pieces near the firewall under the hood. There are 2 of them (one for each side). I know that I can buy them online, but was hoping to get them faster/cheaper. If someone knows, please let me know.
Thanks.
Tony
Lapis Blue 03 Boxster S
Old 10-13-2020, 05:05 AM   #2
Don't hold me to it, but I think I recall them being 5mm. Replaced mine with stainless knurled wide head bolts and new rubber well nuts. I think I cannibalized the well nuts from some motorcycle fairing screw setup. Was a while back so memory may be off.
Old 10-13-2020, 06:12 AM   #3
you can find suitable replacements at a local hardware store (like ACE, TrueValue or DIB) in their MRO open stock bins.
Good luck
"Cool Prius!"
- Nobody
Old 10-13-2020, 06:48 AM   #4
amagalla's Avatar
This is what I was looking to do, but in a lot of cases the bolt gauge at the store is either destroyed or missing. I was hoping to know going in that it's a M5 or M6 that I need.
Old 10-14-2020, 06:15 PM   #5
These were available at our local independent HW store. Nothing special nor were they pricey.
Old 10-14-2020, 06:17 PM   #6
1997 Tip, 2018 Macan
rexcramer's Avatar
Most good hardware stores will have metric nuts and bolts you could use to verify your size.
