Old 10-12-2020, 07:18 AM   #1
2.5 coolant leak
So, I changed the front engine mount, and whilst doing this I had to undo the coolant hoses. Drained the coolant system. Refilled using the ‘’burpe’’ method... all fine. Cycled a few times from cold and adjusted the level just under max.
After driving for 20mins I got a major coolant leak towards the back of the engine / gearbox area.......
Any pointers?
993turbo is offline   Reply With Quote
Old 10-12-2020, 08:25 AM   #2
Need to get back under the car. There’s no coolant lines back that way other than to the oil cooler.
Given you disconnect the coolant hose , I’d start there. Coolant can run and look like it’s coming from areas that it isn’t.
Old 10-12-2020, 12:50 PM   #3
Any pointers?
You don't have a "leak", you have a "dump" from the coolant overflow due to an air pocket somewhere in the cooling system. You didn't "burp" it well enough.............
Old 10-14-2020, 07:37 AM   #4
The vacuum controlled valve at the side of the trans towards the rear had split. Funnily enough its a Porsche 928 part. I had 4 on the shelf.
Old 10-14-2020, 07:39 AM   #5
I know how to bleed these systems. I even cycled it twice from cold, and adjusted the level. And the coolant overflow is on the other side.
Old 10-14-2020, 07:40 AM   #6
Hoses are way forward. This is rear muffler area.
