Old 10-02-2020, 06:38 PM   #1
No throttle after O2 sensor change?
Hey everyone. Just wanted to get some opinions and help. I have a 2000 boxster s and recently changed my O2 sensors with the OEM Bosch ones and after I cleared the codes, my gas pedal no longer functions. Does anybody have any clue as to what I may have done wrong or what I need to do to get it working again?
Sdav86 is offline   Reply With Quote
Old 10-02-2020, 07:06 PM   #2
Did you disconnect the battery at anytime when you did the work?
Have you tried the throttle reset procedure?
I think you turn the key to the on position for one minute but don't start it.
Then turn the key off for 10-20 seconds minimum. Then start it.
Let us know if that works.
Old 10-02-2020, 07:41 PM   #3
I tried the throttle reset, but I'm not sure if I did it right. I'll try again when I get home
