Old 10-02-2020, 07:41 PM   #3
Sdav86
Did you disconnect the battery at anytime when you did the work?
Have you tried the throttle reset procedure?
I think you turn the key to the on position for one minute but don't start it.
Then turn the key off for 10-20 seconds minimum. Then start it.
Let us know if that works.
I tried the throttle reset, but I'm not sure if I did it right. I'll try again when I get home
Sdav86 is offline   Reply With Quote
