Old 09-21-2020, 11:21 AM   #1
Boxster wont start its completely dead
I left the key in the ignition in the off position ,and now NO sign of life,..any info would be great Thanks Frank
Old 09-21-2020, 11:26 AM   #2
what is the battery voltage
Old 09-21-2020, 11:40 AM   #3
Iam off to work but I will ck it tonight..I thought it was a strong Interstate battery key was in it since yesterday afternoon..Thanks
Old 09-22-2020, 05:19 AM   #4
Leaving the key in the ignition drains the battery quite quickly. I have learned not to do that.
1941 Dodge Luxury Liner Coupe
Old 09-22-2020, 08:09 AM   #5
I have a 2003 Boxster S. When I bought it it had one working key. Right or wrong I took the good key apart and relocated the transponder pill next to the cars ignition switch. I then purchased a cut key without any electronics as a second key. second key works perfectly as does first. The interesting exception is that the car never discharges the battery over several weeks of sitting with no battery maintenance. I do not understand others saying the battery drains quickly with the key in the car. That is not my experience.
obthomas is offline   Reply With Quote
Old 09-22-2020, 08:33 AM   #6
Multi-Boxer Driver
Deserion's Avatar
It may be “key in” as in it was turned off and not removed and reinserted. I tend to take mine out and put it back in without turning it, and haven’t had drainage issues.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-22-2020, 12:54 PM   #7
right. turn off car, remove key and reinsert= totally fine
turn off car and leave key as it is=drains battery.
Old 09-22-2020, 03:27 PM   #8
Plus..the fuse box trick did not work ! I have the little pull out jumper,the solenoid clicks just fine but wont open..tried to pull the driver wheel security lug in the trunk So trying to find one on pelican no luck yet ..!! Wont get stolen..or Driven Damn..
Old 09-22-2020, 05:22 PM   #9
Thanks Quadcammer,..You know I will remember this from now on ! Frank
Old 09-22-2020, 06:24 PM   #10
Will there be cake?
tonythetiger's Avatar
ooh...hateful. I removed my locking lugs...but before that, it lived in the center console, available to anyone that wanted to steal my wheels.
let us know how you get in?
Old 09-23-2020, 06:07 AM   #11
Is it safe to jump or charge the battery thru the cigarette lighter ( even if possible ? )
Old 09-23-2020, 07:05 AM   #12
1998 Boxster Silver/Red
Yes. Lots of products to charge through that port. Do a quick search on this forum... you'll find plenty.
Good luck!
1998 Porsche Boxster
Old 09-23-2020, 07:33 AM   #13
Thanks Starter,..Wish I would have thought of this sooner..!! Frank
Old 09-23-2020, 10:35 PM   #14
I noticed that when i turn off the car, leave the key in, open the door and leave the car with the window open, the interior lights stay on indefinitely. I sometimes do this when working on the car.
But, if I pull the key, open the door and close it behind me the light turns off after 10 seconds or so.
That's what I've been careful to do so I don't leave the interior lights on all night.
Steelepuls is offline   Reply With Quote
Old 09-24-2020, 12:04 PM   #15
On the 986, the battery will drain in less than two weeks if not hooked up to a trickle charger. When the battery drains, I have found that more often than not a cell will fail and the battery needs to be replaced.
So either get a trickle charger, or drive it at least every other day.
mgfranz is offline   Reply With Quote
Old 09-24-2020, 03:45 PM   #16
Then you have some parasitic draw on the battery.
For the battery to drain in less than two weeks is not normal.
Old 09-24-2020, 05:19 PM   #17
No, the alarm system on the 986 is horrible, it will drain our battery simply by sitting still. It's a common faukt.
Old 09-25-2020, 04:28 PM   #18
In my case, I was going for a ride fired it up dropped the windows because it was so hot outside, car was in the shade but still hot , So i shut it off went in the house got busy and then forgot the key was in the ignition but turned off. Next day went out to go for a ride and just dead, My wife even said..you told me to never leave the key in the ignition,!!
So i guess i new better Lol
Old 09-30-2020, 11:24 AM   #19
As it turned out,..I used to Cig lighter adapter as soon as I pluged in the charger light's came on popped the trunk, charged battery,..all seems to be fine !
But I would like to know why the fuse panel trick didnt work..anyone have an idea as to why that didnt work ?....Thanks Frank
Old 09-30-2020, 01:39 PM   #20
My guess is you simply didn't have a good connection and I'bet it was on the ground side.
